Intel i3 question
Discussion in 'General Electronics Chat' started by aamirali, Nov 19, 2012.
  1. aamirali
    Feb 2, 2012
    415
    Intel i3 has two cores & it says each core process 2 thread.
    I think Single core can handle 1 thread at one time.
    SO in i3, two threads are handles in round robin fashion???
  2. mcgyvr
    Oct 15, 2009
    4,793
    976
  3. vpoko
    Member
    Jan 5, 2012
    258
    47
    There are two sets of registers per core, but only one execution unit (ALU, FPU, etc), which can work with either register set.
  4. aamirali
    Feb 2, 2012
    415
    1. I have read that current in processor is TDP=VI.
    Normally voltage is around typical 1V around. So max current can go upto 65A???.
    2. Is it safe to overclock processor with simple fan as which comes with CPU
  5. toffee_pie
    Oct 31, 2009
    162
    7
    you can over clock until the cows come home or until temps dont go above 90 degrees, whichever comes first. :)
  6. vpoko
    Member
    Jan 5, 2012
    258
    47
    You're not going to see 65A going through any single transistor in the CPU, but because there are so many transistors, that is the total current going through the CPU.
    It depends on many factors: how much you're overclocking, how you're overclocking (whether overvolting or just using a different clock multiplier), how big your case is, how good the stock fan is, etc. The important thing is that the CPU temperature stays within specifications. One thing to think about is that PC manufacturers don't like wasting money. Therefore, they're not going to put in a much better CPU fan than needed, which means that while you may have some cushion, you probably don't have much.
  7. mcgyvr
    Oct 15, 2009
    4,793
    976
    A stock fan/heatsink is NEVER good for any level of overclocking. Don't even try.
  8. kubeek
    Sep 20, 2005
    4,691
    806
    I overclocked my Q8200 processor from 2.33GHz to 2.66GHz with the boxed heatsink without any trouble.
