intel Core i7-900 processor
Discussion in 'General Electronics Chat' started by logicman112, May 9, 2010.
  1. logicman112
    Thread Starter Active Member
    Dec 27, 2008
    69
    Does Core i7-900 processor have separate physical address/data pins for x87 FPU integrated coprocessor unit?
  2. rjenkins
    Nov 6, 2005
    1,015
    69
    Without looking at the datasheet (hint!), I would think not.
    Newer CPUs have multiple execution units and multiple integer & floating point math units.The whole lot is going to be heavily integrated with the rest of the CPU.
    Although the result may be equivalent to an x87 as far as software is concerned, I think you can pretty much guarantee it will be almost unrecognisable as far as the physical design goes.
  3. kubeek
    Sep 20, 2005
    4,691
    806
    the word INTEGRATED really means that the floating point instructions are "virtually executed by the x87 chip" but in reality there is no x87 chip inside. AFAIK since 486 the x87 chip is no longer separate and is a part of the processor.
  4. logicman112
    Dec 27, 2008
    69
    Thank you very much for the replies. The reason I guessed CPU has some pins for x87(or a protocol to access to a separate address space for FPU) was that the basic execution environment of IA-32 shows two registers:
    48 bits FPU instruction pointer register
    48 bits FPU data pointer register
    It seems it has some pointers to access instruction/data , what are those then?
