I recently had to interface with some old lab equipment. It had a db25 pin serial connector. The serial card for the instrument was based on the Intel 8088. When I hooked up all the serial lines on the connector, there were still a couple of pins left over on the connector that had traces connected to them.
The first was pin 14 of the db connector. It was attached to the output of a serial driver to PCR5 (port B strobe) of the Intel 8155H Mos Ram.
The second was pin 18 of the connector. It was attached to the input of a tied low not gate to the NMI pin of the 8088.
Basically I am wondering what the functionality/use of these pins might be in controlling my instrument and whether it would make sense to connect them to my serial cable somewhere. I did read that the NMI was sometimes used for power failure protection, but I suppose the interrupt could trigger any subroutine. As for the strobe, I have no idea. Pins 1 (carrier detect) and 9 (ring indicator) are still available on my serial cable.
