intel 8085 microprocessor and 8155 PIA
Discussion in 'Homework Help' started by reggea07, Dec 17, 2011.
  1. reggea07
    Aug 8, 2011
    [​IMG][​IMG][​IMG][​IMG][​IMG] Uploaded with ImageShack.us
    tester circuit
    the operation of the Ic tester is follows:
    *wait until the push-button switch is pressed
    *when the push-button is pressed, debounce the switches contacts by delaying to read swicth output
    *Send a logic 0 0
    0 1
    1 0
    1 1
    to gate inputs
    *read gate outputs 1
    *read gate outputs . if all the gate outputs are right , assume that the gate is working and turn ON the green led
    otherwise assume that the chip is faulty and turn On the red led
    Design Hardware and write software (assembly language 8085 micro)
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Are you designing 8085 kit or just using ready made kit??
  3. reggea07
    Aug 8, 2011
    no sketch theoretically hardware design
    this is my homework
    lecturer solved inverter tester and gave us this problem
    please help me.....
  4. t06afre
    May 11, 2009
    5,939
    1,222
