Integrator triangular wave
Discussion in 'The Projects Forum' started by thiagofdp, Nov 6, 2014.
  1. thiagofdp
    Nov 6, 2014
    Guys, I need help with this project.
    I have this circuit
    This is the project
    Here's what I want from V1
    Can someone give me a hand? Thanks in advance
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What frequency, rise time, fall time, are you trying to achieve?
    R3*C1 determines the rise time. R4*C1 determines the fall time. The sum of these determines period = 1/frequency.
    10*R2/R1 determines amplitude.
    I question why the inverting input of the second opamp is connect to +5V instead of ground?
  3. thiagofdp
    Nov 6, 2014
    it's on the third picture..
    rise time 500ms
    fall time 1000ms
    thanks
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Reread my previous post.
  5. thiagofdp
    Nov 6, 2014
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    Looks like your math is good. Note that the sim and your analysis depends on the opamps being rail-to-rail output. Note V(b); see how close it must pull to the rails... Note I used repeated trials to get close to your 1500ms period.
  7. thiagofdp
    Nov 6, 2014
    Thanks a bunch!
    But it would be a nice a capacitor of lower value, because the period is too damn big
    I tried 500k, 1M and 10nF, doesn't work that well... Can you show me how you calculated R3, R4 and C1?
    Thans a lot.
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    The times are a little difficult to calculate because of the 5V bias on the Schmitt stage. I just played around with R and C until the rise time ~ 1s and fall time ~0.5s. The time constant is roughly R*C = 1e6*1e-6 or 1meg and 1uF gives one second. The input bias current of the opamps puts an upper bound on R. I wouldn't go much over ~1meg. So you are stuck with C.
