Integrator Op Amp help
Discussion in 'Homework Help' started by MrGeorge, Aug 16, 2011.
  1. MrGeorge
    Aug 16, 2011
    5
    Hi there!
    I'm having trouble with Intergalactic Op amps. I'm fairly new on the subject, I've seen lots of stuff on the internet regarding a DC Input but nothing regarding Sine waves.
    I've attached the question so anyone can have a look at it, I am suppose to draw the output.
    So far I've got:
    Vout = -Vin/RC
    When Vin = 5mv, vout -= -10mV
    When Vin =-5mv. vout = 10mV
    I know there is also a phase shift, I suspect it'd be either + or - 90 degrees.
    I have no idea how correct this is or even if I'm on the right track. A bit of help would be great :)
    Thanks guys, I swear by your tutorials!
      File size:
      6.8 KB
      29
  2. blah2222
    May 3, 2010
    565
    33
    You're on the right track. Have you ever used phasors before? They are a nice way of dealing with sinusoids instead of dealing with differential equations. You basically transform each component into its phasor form then solve the circuit like you normally would, turning a differential equation problem into an algebraic problem.
    JP
