Integrator op amp-derivation help
u-will-neva-no
Joined Mar 22, 2011
230
Hey everyone, I have attached the question and solution to this problem but do not arrive at the same solution. My problem is that I do not know how to use the \(Ib_2\) current so my approach was just to say that another current would flow through the capacitor and that is equal to the current flowing through the resistor:
\(I_r_e_s = I_c_a_p\)
\( \frac{v_i - 0}{R} = -c\frac{dV_o}{dt}\)
\(-\frac{v_o}{RC} = \frac{dv_o}{dt}\)
\(V_o(t) = -\frac{1}{RC} \int^t_0 V_i(t) + V_o(0)\)
so \(V_o(t) = -\frac{1}{RC} \int^t_0 V_i(t) \)
Any advice why the above is not applicable to this question and how I should go about it? Thanks!
u-will-neva-no
Joined Mar 22, 2011
230
Okay I think its Ires= Ic1+Icap but I have always learnt that a current flowing into the inverting op-amp is 0; thus Ic1=0 (ideally). This results in what I had previously using KCL..
Ron H
Joined Apr 14, 2005
7,063
THe key word here is "ideally". Not all real-world op amps have insignificant input bias current. I do think this is a poorly formulated question, because you still have to assume that open loop gain=∞ and input offset voltage=0 in order to solve it. If the op amp is not ideal, then all parameters that are relevant to the problem should be listed, IMHO.
