integrator if the frequency used had been 100Hz
Discussion in 'Homework Help' started by Sun Mi Kang, Nov 12, 2009.
  1. Sun Mi Kang
    May 17, 2009
    HI~! GUyz
    I'm from Korea, I studied electronic engineering,, I'm a girl.,.
    It is report of my experiment,,
    My experiment is about the integrator and diffrentiator
    I want to help my question,,
    Q. What effect would you expect on the output of the integrator in Figure if the frequency used had been 100 Hz instead of 1kHz?
    I attached to my figure in below..
    I think that when the frequecy is decreased, integrator output would be low pass filter frequency,,
    Anybody, explain to me.. I want to know exactly,,
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Hint: does the integrating capacitor have the ability to soak up 10 times the charge? If not, what will happen?
  3. KL7AJ
    Nov 4, 2008
    2,043
    292
    Actually, the output voltage will be GREATER. The capacitor will have more time between cycles to charge up. (Remember the RC time constant).
    Eric
