Integration for Power in an RL ac circuit
Discussion in 'Homework Help' started by Tera-Scale, Jan 14, 2011.
  1. Tera-Scale
    Thread Starter Active Member
    Jan 1, 2011
    164
    5
    Does anybody have some good links on where I can read about deriving Power in an ac cycle for an LR circuit by integration. I have equations for instantaneous current and instantaneous voltage and even the impedance.
    v=315sin(100pi*t)Volts
    i=3.665sin(100pi*t-0.374)Amps
    z= (80 + j10*pi)Ω
    I manage to obtain the perfect graps for current voltage and power but the thing is that when I am integrating (definite) I am getting zero all the time :s
  2. edgetrigger
    Member
    Dec 19, 2010
    133
    19
    integrate product of Vrms and Irms from 0 to 2∏, you'll get a finite non zero value.
  3. Tera-Scale
    Jan 1, 2011
    164
    5
    I got a strange number :s ... what does it represent exactly? It's nowhere near P=(Vrms squared)/Z or P=(Irms squared) * Z
    Since I have to comment between the different results obtained. The difference is huge from the result you told me (3626.89) and the P's i mentioned of 577.25Watts.
    thanks
    Brandon
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    As a check the average power would be Vrms*Irms*cos(θ)
    Vrms=315/√2=222.74
    Irms=3.665/√2=2.59
    cos(θ)=cos(0.374[rad])=0.931 - presumably θ was stated in radians.
    Hence
    Pav=222.74*2.59*0.931=537W
  5. Tera-Scale
    Jan 1, 2011
    164
    5
    Yes, I considered that check but now I am stuck on what and how to integrate. I am asked to find the power in the first cycle and what I did was finding the area of voltage of the first half(0-0.01) and then the 2nd(0.01-0.02) And the same for the current but everything cancels out. :s Why is it that i have a negative area of power on the second half when i plot the graph it wasn't that way.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Check this ...
  7. Tera-Scale
    Jan 1, 2011
    164
    5
    Lovely.. thanks buddy. One day I want to help other people like you. This summer I plan to contribute to this site in some way or another.
    thanks again
    Brandon
