Insulating wire
Discussion in 'General Electronics Chat' started by LDC3, Jul 2, 2013.
  1. LDC3
    Thread Starter Active Member
    Apr 27, 2013
    920
    160
    I recently bought some bare nichrome wire and I would like to know how to insulate it so I can make a coil to place in front of a fan to heat the air.
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    Have a look at the picture of this hairdryer on how stuff works:
    http://home.howstuffworks.com/hair-dryer3.htm
    The wire is wounded around a crossed piece wich looks like mica.
    Also ceramic material would work.
    Bertus
  3. KJ6EAD
    Apr 30, 2011
    1,426
    363
    The usual way is to leave the wire bare and arrange it on ceramic insulators. In some lower temperature applications it can be sleeved with teflon or silicone tubing.
  4. wmodavis
    Oct 23, 2010
    737
    150
    Electrical insulation will also insulate for heat transfer which sounds like your intended purpose.
  5. crutschow
    Mar 14, 2008
    13,475
    3,361
    What are you insulating it from?
  6. tracecom
    Apr 16, 2010
    3,878
    1,396
    I tried lots of materials, but only two worked: ceramic and mica. Mica is better, but more fragile to work with. For ceramic, I bought some small tile pieces at Lowe's and used a diamond point drill to penetrate them. Either way, you then face the problem of connecting the nichrome to the copper feed wires. I ended up using mechanical (e.g., nut and bolt) connections.
    You can also wind a coil on a bolt, and then turn the coil off the bolt, and let air be your insulation. Just don't let the turns touch or your resistance will be lowered. Here's a good introduction.
    http://www.cecs.wright.edu/balloon/images/2/22/Nichrome_Wire_Heating_Element_Design_Basics.pdf
  7. studiot
    Nov 9, 2007
    5,005
    515
    Get some chemists' glass strirring rods or tube, cut into suitable lengths.
    Stick the rods into a blob of epoxy putty as a hub and create a star like the spokes of a wheel.
    Wind the nichrome wire in a spiral fashion, over and under the rods, round and round like a spider web or basket weave fashion.
    This will create a rigid, self supporting, heatproof structure you can use.
    PackratKing likes this.
