Instrumentation Amplifier output
Discussion in 'General Electronics Chat' started by Dritech, Nov 28, 2015.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    I did a basic circuit on simula ion, where I used the AD621 and provided a common input.
    Why is the output of the IA not measuring 0V? I also tried another IA and I got similar results.
    Any help would he highly appreciated.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Try it with +- split supplies. The data sheet doesn' t say anything about its rail-to-rail operation with a single supply. In fact, the data sheet implies that split supplies are required.
  3. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the reply. I want to use the IA with a bridge. With reference to the schematic below, since all resistors are equal, shouldn't the output of the IA be 0V?
  4. hp1729
    Nov 23, 2015
    2,098
    232
    That is almost right out of the data sheet. Yes, it quotes only split supplies but an example in the data sheet shows single supply operation in a similar circuit. Have you tried modeling it with another (simpler) IC that says it is designed for single supply operation?
  5. Alec_t
    Sep 17, 2013
    5,976
    1,136
    :confused: I think there is something wrong with the simulator or with the AD621 model: the amp output at pin 6 is apparently -3.49V with a single-polarity supply !
  6. Dritech
    Sep 21, 2011
    756
    5
    When I connected pin 4 to -12V using the circuit shown in post #4, the meter measures -15V :confused:
  7. Veracohr
    Jan 3, 2011
    559
    77
    Was pin 5 still grounded when you used split supplies? It's the reference pin.
  8. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    One problem is that Vref pin 5 is strapped to what the amp considers the negative PS rail (Vs). The specs say this pin should be 1.6v above Vs. Try setting it to Vcc/2 for single supply operation.
    Dritech likes this.
  9. Dritech
    Sep 21, 2011
    756
    5
    Thanks all for the replies. I did as JohnlnTX suggested (pin 5 set to 6V) and it worked.
    What method should I use to make the output go to 0V when both inputs are equal?
    I tried using a dual supply (12V and -12V) and setting the reference pin to ground, but it did not work.
  10. hp1729
    Nov 23, 2015
    2,098
    232
    Okay, assuming the simulator is wrong ... what do you get if you actually breadboard the design?
  11. hp1729
    Nov 23, 2015
    2,098
    232
    re: returning Ref to V/2 ... Super! That agrees with the example in the data sheet.
  12. Alec_t
    Sep 17, 2013
    5,976
    1,136
    I've no idea. I've never had/used an AD621.
  13. hp1729
    Nov 23, 2015
    2,098
    232
    Very pricey, about $10 a piece. Bipolar input. Well less than 1 MHz frequency range. I would need a good reason to justify it. Low noise, low CMRR, precise gain?
    Is it really needed in this design?
  14. Alec_t
    Sep 17, 2013
    5,976
    1,136
    Only you know what precision, linearity and stability you need.
