i had been using unity buffer (Tl082) and INAmp(INA129) to amplify some low signal (very low voltage and relatively high noise). Even though the gain in simulation and the circuit test using function generator looks perfect its not in the real case. Both the ICs are quite older and i assume i should go for a modern IC with low input noise. Can someone suggest me a better replacement for the ICs. Or advoce is appreciable.....
NB. the frequency of my input signal is very low (1~20 Hz)
