Instantaneous analog input to a pic
Discussion in 'The Projects Forum' started by addleme, Mar 12, 2011.
  1. addleme
    Dec 16, 2008
    Hello guys,
    I have a question about my term project. In the project, we have an instantaneous analog output coming from a sensor such that the sensor senses the distance of a passing ball which stays in the range of the sensor for very short time. The question is that; can we transfer this instantaneous output to a microprocessor (atmega1280) and can the processor sense this output properly or do we have an extra circuitry to achieve this goal.
    Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you tell us more about the analog signal? What information does it carry?
  3. John P
    Oct 14, 2008
    1,638
    225
    I think "instantaneous" as it applies to your ball will be pretty leisurely as seen by a microprocessor.
    For instance, you could run the A/D converter at 10000 samples per second, and look for a rising output (assuming close target means high level) that then starts to fall, and hold onto the peak output and time at which it occurred.
