Install teamviewer; raspiberry pi; wine
Discussion in 'Embedded Systems and Microcontrollers' started by Vindhyachal Takniki, Nov 18, 2015.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    http://wiki.winehq.org/ARM ; site tells that wine can now run x86 apps on arm architecture also.
    I need to install Teamviewer on raspiberry Pi 2 with raspbian loaded & will check if it works or not.
    Problem is how to install winehq in RPi2. I tried to run "sudo apt-get install wine", but it failed. I think that's because it is x86 based. How to install wine for ARM?
  2. nerdegutta
    Dec 15, 2009
    2,569
    806
    How did it fail?
    Have you checked the respositories?
    Can't you download WINE as a package, and install it with dpkg?
  3. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    I had used sudo-apt get install wine. It failed by saying binaries not installable.
  4. nsaspook
    Aug 27, 2009
    3,017
    2,378
  5. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    @nsaspook , i will see & run that.
    Can't use exagear though, looking for some freeware alternatives.
