I am with #12, if hd is not detected at POST, then there is nothing anyone at home can do.Thanks. I'll try that on some of the HDDs that get detected when I plug them in.
I doubt it will do any good on HDDs that don't even get detected, but I have a lot to learn.
What are you talking about?Anyone else have any tricks to get this new HDD to format and install Windows 8?
Or, any other OS??
The computer came with Vista Home Premium installed, then I upgraded to Windows 7, then Windows 8.....then Windows 8.1.
Worked great for 3 years, until I started it up, then black screen. I even tried to use the original Vista disc to re-install.....no luck.
When you take your computer to the shop......what do they use to make a brand new HDD work?
If they can do it, there must be a way for the home user to boot it up, and install it correctly.
Right?
Or buy a new computer. If it worked great for 3 years, how old was it total Metalmann?What are you talking about?
* Connect the new hd.
* Start comp, go into bios, set it to boot from cd/dvd, save and exit. Pop OS cd/dvd into cd/dvd drive.
*Restart comp, follow installation instructions.
Try setting up a Linux Live CD, and using the BIOS to boot up to it. The CD should recognize the harddrive. Many of them come with a program called GParted, that is used to partition and format hard drives. I would use this to firstly, install a partition table on the device, and secondly, format it to NFTS filesystem, which Windows uses. Then you should be able to boot up to the Windows install CD to install to the harddrive.
Thank you, I just downloaded the files. Hopefully it will work.....
That's one way to fix it.I solved that little problem, after frying my brain for a few weeks.:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8563604
Now that everything is up to date, I had forgotten how fast a computer can be.
Thank you to the guys who tried to help!
by Dale Wilson
by Jake Hertz
by Duane Benson
