Inserting a pulse to a LPF / HPF
Discussion in 'General Electronics Chat' started by EngIntoHW, Sep 3, 2010.
  1. EngIntoHW
    Apr 24, 2010
    128
    How would the outputs look like in the following cases:
    I know how the outputs would look like in the frequency domain, but I don't know how they'd look like in the time domain.
    How do you derive it?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The LPF will have trouble following the rapid rise and fall of the leading and trailing edges of the pulse, but will tend to eventually follow the steady state high level and 0V values of the pulse.
    The HPF will better follow the rapidly changing edges of the pulse but have relatively poor response to the steady state portions of the pulse.
    Consider applying a pulse to a simple RC network configured either as a low pass network or as a high pass network.
  3. marshallf3
    Jul 26, 2010
    2,358
    201
    Different type filter designs are going to produce different results as well.
  4. EngIntoHW
    Apr 24, 2010
    128
    Hey,
    Could you please give examples for LPFs and HPFs that don't just use capacitors, resistors and inductors?
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  6. EngIntoHW
    Apr 24, 2010
    128
    Thanks Bertus :)
