Ins and Outs
Discussion in 'General Electronics Chat' started by Metalmann, Nov 27, 2013.
  1. Metalmann
    Thread Starter Active Member
    Dec 8, 2012
    700
    223
    I'm having trouble with some schematics, regarding the ins and outs.
    I'm posting a pic from Blah2222's thread.
    I don't see where the current/voltage enters, and exits.......:confused:
    Probably simple......but I'm stumped.:confused:
    Some schematics are pretty easy.
      File size:
      34.5 KB
      35
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    Well the 2 circles (ref des V2 and V3) with the + and - are voltage sources..
    Obviously some of that schematic is missing too after the LT1492 IC
    Metalmann likes this.
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    Enters and exits... what? The LT 1920? The circuit as a whole?
    Try to identify specific questions, such as "Where does the "+2.5V" that is shown in several places come from?"
    Otherwise we will be answering questions you don't have and not answering questions you do.
  4. Jony130
    Feb 17, 2009
    3,991
    1,116
    Input signal is represent by V2 AC voltage source. Input signals enters IN pin of a LT1920 (instrumentation amplifier). After the gain signal is present at the OUT pin.
    Next signal pass through high pass filter (C3, R10) and enters non inverting amplifier (U1).
    V3 is a 5V DC supply voltage. R3,R4 and voltage follower (U2) creates +2.5V reference voltage (virtual ground). Needed to proper bias op amp from single 5V supply voltage.
  5. GopherT
    Nov 23, 2012
    6,313
    4,031
    Described perfectly.
