Inrush current
Discussion in 'General Electronics Chat' started by universboy, Jan 27, 2005.
  1. universboy
    Jan 27, 2005
    I have a problem. I2m using toroidal transformer, but when I switched on,
    it blows fuses 25A, How can I eliminate the inrush current?
    Best Regards.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I'd start by looking for a wiring problem or a shorted primary in the transformer. That's a lot of current draw.
    If all is well, look for inrush current limiters. I'm using one on my big stereo amp, so it just turns on now - it used to dim the room lights. If the problem is only at turn on, though, consider a slo-blow fuse.
  3. universboy
    Jan 27, 2005
    There is no wiring problem , all the problem is inrush current. can you send me part number or name or circuit for inrush current limiter?
    Best Regards.
    [post=4853]Quoted post[/post]​
    [/quote]
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I don't have enough data to make any guesses, but check out Panasonic's line of ZNR transient surge absorbers. Get some data and application sheets to make a selection. Digi-Key carries a couple of pages of them in their catalog (digikey.com).
  5. Brandon
    Dec 14, 2004
    306
    Whats your transformer specs (turns on primary, secondary, core size and composition) and what are you trying to have it do? (primary voltage/current and secondary voltage/current)
    I have some experience with making torroidal transformers as I had to design one for a project at school to build a stepup switching DC/DC.
