Inrush current
Discussion in 'General Electronics Chat' started by cpleng7, Jul 28, 2010.
  1. cpleng7
    Thread Starter Active Member
    Dec 18, 2008
    120
    Did someone know any equipment can measure the inrush current for induction motor or transformer?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Something like a current transformer and a fast digitizer might work. Perhaps an o'scope set to single sweep if you don't need a lot of precision.
  3. someonesdad
    Jul 7, 2009
    1,585
    141
    In addition to the scope, many clamp-on ammeters have the ability to measure inrush current. As long as you understand that they are sampled measurements and can miss the true peak current, they may get you close to want you want. If you really need to know the actual peak current, use a scope with a suitable transducer (current transformer, clamp-on current probe, Hall effect probe, resistor, etc.).
  4. timrobbins
    Aug 29, 2009
    318
    16
  5. John Luciani
    Apr 3, 2007
    477
    A current probe and an oscilloscope will work. Tektronix makes a couple of
    different probes and interface modules (amplifiers). The amplifier output plugs
    into the oscilloscope input.
    (* jcl *)
