inquiry on what is difference bw RMS & peak
Discussion in 'General Electronics Chat' started by bramin19, Feb 7, 2011.
  1. bramin19
    Feb 7, 2011
    what is the difference between 40 volts DC and 40 volts RMS and 40 volts avg signals?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    RMS stands for Root Mean Square. It is as much a mathematical concept as an electronic one. With a sine wave RMS is 0.707 of peak voltage. RMS voltage will heat a resistor (dissipate wattage) as an equivalent DC voltage of the same value.
    However, this is for a sine wave. For a square wave RMS equals peak voltage. For other waveforms the number will be different.
    http://www.opamp-electronics.com/tutorials/measurements_of_ac_magnitude_2_01_03.htm
