input voltage of PIC16F877A
Discussion in 'Embedded Systems and Microcontrollers' started by alarassi, Feb 6, 2010.
  1. alarassi
    Feb 6, 2010
    hello everybody​
    im new here and looking for ur help all ;)
    i'm doing heart sound monitoring system that detects and amplifies the heart sound and then displays the waveform of the sound on graphic LCD by using PIC16F877A​
    i need to understand few things befor i start my project!​
    how much input voltage in range can the PIC16F877A recieve (output of the ampified signal )!? bcz i want to amplify the signal but i want to know until whic range of values!!
    it's a sound signal so that means the output will be fed in to the ADC of the PIC!!​
    i searched on the datasheet but im very new on PICs so couldn't really understand it!​
    thank you​
  2. lkgan
    Dec 18, 2009
    A regulated 5V power supply should be sufficient to power up PIC. Can use LM7805 regulated IC if you want to.
  3. JDT
    Feb 12, 2009
    The signal on the ADC inputs can be between 0V and the supply voltage (normally 5V)
  4. alarassi
    Feb 6, 2010
    thank you for ur reply, but what i mean here is the output of the amplified signal which is the input to ADC of pic..!
    what u mentioned here was the operation voltage!!
    thank you
  5. alarassi
    Feb 6, 2010
    thank you for ur answer,
    so that means it doesn't receive negative voltages! right?
    on the data sheet i read something about Vref, can u explain to me what's it exactly ?
  6. t06afre
    May 11, 2009
  7. xixihaha
    Feb 6, 2010
    I didn't use PIC before, but MSP430 instead. I think when you use ADC in PIC, you can use the chip power supply(5V) as reference which others mentioned above, or you can input another voltage as a reference, but make sure the maxium voltage the pin can afford in datasheet.
