input voltage for op amp
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Sep 10, 2011.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    why the input(the 2 input +&-) for op amp are the same(negative feed back)
    how can i prove this
  2. joeyd999
    Jun 6, 2011
    2,759
    2,943
    There is nothing to "prove". This is by definition for an op amp operating closed loop. Actually, there will be a small difference (ignoring input offset voltage) due to the finite open loop gain. The difference * (open-loop gain) = output. The open-loop gain is usually so large that it can be ignored in most cases, and the assumption that in+ = in- is valid.
    TAKYMOUNIR likes this.
