Input switching
Status
Not open for further replies.
vdubin
Joined Sep 22, 2009
7
Hey guys... I am working on a custom sign using leds. The problem i have is, full brightness to be seen during the day will be blinding at night. I was thinking of using a switching relay for power and having a resistor on one leg, triggered by an exterior light circuit to power the signs. What i have been looking into, is using a transistor setup to try for a solid state system that i can keep out of the weather.
Any ideas? The load would be quite small 2-3 amps at 12-14v with a 12-14v trigger.
#12
Joined Nov 30, 2010
18,224
I disagree with the idea that you are going to "improve" a system that only uses one relay and one resistor by building a transistor rig. Just use a store-bought eyeball to fire a 120 VAC relay coil and have that one relay connect or disconnect a resistor.
Status
