Input signals to ADC
Discussion in 'General Electronics Chat' started by new2circuits, Apr 22, 2009.
  1. new2circuits
    Apr 22, 2009
    21
    Can someone explain the different types of input signals acceptable by an ADC ? from what i understand, the signal (sine wave for example i believe is one type)will have a Voltage (amplitued of sine wave) associated with it. Is this correct ?
    Is there a web sit, white paper, or some other source that explains this at a rudimentary level for a novice ?
    Thanks in advance.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is a link to some of the material on the topic of ADC applications contained in the AAC ebook section.
    hgmjr
  4. new2circuits
    Apr 22, 2009
    21
    Thanks for the help everyone.
    This enlightened me. I have to go back to the basics and understand what constitutes +Vin and -Vin a bit more so I can forumlate more insightgul questions. Thanks again.
  5. mik3
    Feb 4, 2008
    4,846
    63
    You need to consider the frequency of the signal too and not only its amplitude. It is important to check if your ADC module can respond to the rate of change of the signal.
