Hey waynehYou need to better specify your question. Are you asking about the base current, and its impedance?
Hey alecAt which terminal is your 'input'?
The transistor junctions have inherent capacitance, therefore their AC impedance is frequency-dependent.
It's low! It's basically a diode and will conduct enough current to destroy itself if you don't control the base current. Look up the diode equation if you want to estimate how the "resistance" changes with current. Then look for information in the data sheet that may give you reference points on the diode curve.Hey wayneh
i mean the resistance between base and emmitter when the transistor is on
http://forum.allaboutcircuits.com/blog/turn-on-voltage-of-a-bipolar-transistor-vbe-ic.571/Look up the diode equation if you want to estimate how the "resistance" changes with current.
by Jake Hertz
by Duane Benson
by Duane Benson
