The Electrician
- Joined Oct 9, 2007
- 2,970
It IS necessary at low frequency if you want to have the highest gain possible. Jony said in post #14 "Also I don't see any capacitor between M2 gate and GND?"Sorry, I still don't quite understand.
You said that the gate of M2 must be grounded at high frequency and we can do that by placing a capacitor between gate of M2 and ground.
However, could you explain why we need to ground gate of M2 at high frequency while it is not necessary at low frequency?
You responded:
"yes, you are right. I used capacitor in place of R2 in the topology. However,
last week, I go to a university and asked a friend of mine for help. He said that I can use resistance instead of a capacitor provided that they have the same impedance. Therefore, I draw a resistor here."
For a cascode, you should have ZERO impedance to ground. Since the resistors R1 and R2 are providing the bias for M2, they can't be zero ohms; only a capacitor can provide an impedance approaching zero ohms without shorting out the DC bias voltage.
Even at low frequencies it's a good idea to have a capacitor to ground at that node. Furthermore, neither R1 nor R2 goes to ground in your circuit because Rs is not zero ohms.
