Input Resistance - LM741 Circuit
Discussion in 'Homework Help' started by Zaraphrax, Sep 4, 2009.
  1. Zaraphrax
    Thread Starter Active Member
    Mar 21, 2009
    47
    G'day,
    I'm trying to calculate the input resistance of an op-amp circuit. I already know that an op-amp by itself has an input resistance of around 2 mega-ohms.
    I have a 50 kilo-ohm resistor, hooked up to a voltage follower (LM741 with the output fed back to the negative input - giving no voltage gain), with the output from this hooked up to an inverting amplifier that looks like this:
    Where R1 = 22 kilo-ohms and R2 = 220 kilo-ohms, this gives a voltage gain of -0.1 (-R1/R2).
    I can't find any info in my text books aside from that the value itself is around 2 Mega-ohms, and that inverting amplifiers can reduce the input impedance. However I'm not sure how to go about calculating this.
    Thanks.
  2. mik3
    Feb 4, 2008
    4,846
    63
    Gain=-R2/R1
    Thus, if R2=220K and R1=22K then the gain is -10.
    The inverting input is very close to 0V.
    Thus the input current is:
    Iin=Vin/R1
    The input resistance is:
    Rin=Vin/Iin=Vin/(Vin/R1)=R1
