Input/Output Voltage Class C RF Amp
dccircuit
Joined Aug 3, 2014
Hi all:
I am a new member here with my first post. I am an adult learner trying to self-teach RF electronics. I have been working through David Rutledge's Electronics of Radio, while building the NorCal 40A transceiver.
I am getting caught up on understanding the Class C RF power amplifier circuit.
I don't understand how the output voltage across the collector of Q7 can be more than twice the DC supply voltage (12VDC). I assume that the reactive components--such as RFC1--are storing energy?
Any help would be appreciated. I have included the schematic.
SLK001
Joined Nov 29, 2011
1,549
You could have an inphase reflection that will double the peak to peak voltage at the collector. The 43V zener diode is a last ditch effort to protect the power transistor from Vce breakdown failure. Your output capacitors also need a breakdown voltage at least 4 times the static DC voltages.
Also, this post should be in the Radio and Communications section of the forum.
