Input / Output Protection
malkc
Joined Feb 7, 2010
Here is what I have specified (so far):
DC output Power:
300mA output minimum
Overcurrent Protected (fuse blows?)
Miswire: up to 265VAC, still operates, but miswire is indicated
Transient/Surge source: Lightning
DC Inputs 1-5:
Off Voltage: 0V
On Voltage: 12V
Reverse Voltage: 12VDC
DC Outputs 1:
Off Voltage: 0V
On Voltage: 12 V
Output Max Current 1A.
DC Outputs 2-3:
Off Voltage: 0V
On Voltage: 12 V
Output Max Load: 1kohm resistive
Miswire: output protected up to 265VAC, still operates, but miswire is indicated
attached is my input circuit utilizing a rectifier / dep mode fet / opto, but it doesn't indicate a miswire.
also, i really like using a comparator input so i can set the threshold voltage. maybe i can't have it all?
Please advise if you have a good suggestion.
