Input Noise Floor of preamplifiers
Discussion in 'General Electronics Chat' started by naumankalia, May 17, 2016.
  1. naumankalia
    Feb 19, 2016
    17
    Hi all
    I am designing a variable gain pre-amplifier using AD604 at input stage and a band pass filter at AD604 output. I want to calculate theoretically the input noise floor of this whole preamp which will tell me the minimum input signal level detectable by it.
    Can any one kindly guide me how to do it?
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    His first statement is the best, "this can be a real big can of worms so I just going to open it just a little."
    nsaspook and ronv like this.
  3. naumankalia
    Feb 19, 2016
    17
    Thanks for help
  4. naumankalia
    Feb 19, 2016
    17
    Hi all
    This was indeed a very good tutorial related to Op-amp noise, however my problem is little bit more complicated as i have lot of resistor-capacitors as well as multiple of Op-Amps. Is there any software which can calculate theoretically the input/output noise levels of complicated circuits taking into account the parameters of different components used in it?
  5. #12
    Nov 30, 2010
    16,704
    7,344
    I think you're looking for a circuit simulator like LTspice, but I'm not sure because I don't simulate.
