Input linear range of mosfet
Discussion in 'Homework Help' started by njdubbs, Apr 29, 2013.
  1. njdubbs
    Apr 29, 2013
    Hello I am trying to prove the input linear range of a sat. mosfet is vgs <= 0.2(VGS-VTN). HELP. Assuming the MOSFET is in active mode, id=(kn/2)*(vGS-Vtn)^2 --> id=Id+gm*vgs, gm=2*Id/(VGS-VTN) --> vgs=(id-Id)/gm --> vgs=(id-Id)/(2*Id/(VGS-VTN)) then i am stuck....how do you know how much you can vary the drain current? This is a small signal model btw.
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    You have to define what is meant by "linear". You have a relationship between two parameters, say a voltage and a current, that is off the form:
    i(v) = f(v)
    The small signal resistance is
    r(v) = dv/df(v) = r + dr(v)]
    This is "linear" to within ε as long as |dr(v)/r| < ε. The range of v for which this is true is the "linear range".
    Not surprisingly, if you want it to be linear within 0.01% then the linear range is generally going to be considerably smaller than if you only need it to be linear within 10%.
