Input filter thoughts..
Discussion in 'General Electronics Chat' started by rblilja, Jun 12, 2012.
  1. rblilja
    Jun 11, 2012
    I'm designing an input filter for a DC/DC converter (voltage-programmed). The converter will provide power to quite a few PWM controlled loads working at 10 to 20 kHz, the total current going through the filter will roughly be 2.5A.
    There are a few things I need to verify..
    1. Looking at my attached circuits and plot (Zipped LTSpice files), have I correctly calculated the filter's output impedance by adding an AC voltage source to the output and plotting Vout / Iout on an linear scale?
    2. Is the common mode choke both working as a common mode filter and a differential filter with this setup? Or should I add a pi-filter (CLC) after the common mode choke?
    I appreciate all suggestions of improvements / corrections.
    Thank you.
