Input Dynamic range of Op-Amp circuits
testing12
Joined Jan 30, 2011
80
Hello Everyone,
Im looking for some help with calculating the input dynamic range of the op-Amp circuit below. Can someone please direct me?
I know that if V1(t) falls outside the input dynamic range, the circuit saturates, ie goes to either +/- 13 volts..Just not sure how to find the range.
Thank you.
testing12
Joined Jan 30, 2011
80
Here is ym attempt: for a summing amplifier:
V(out)= - (Rf/R1)*v1 -(Rf/R2)*v2
13 = -(33/10) *(v1) - (33/100) *(2)
v1= +/- 4.14 volts
t_n_k
Joined Mar 6, 2009
5,455
You effectively have an inverting / summing amplifier.
Vo(t)=-(K1*Vb(t) + K2*Va(t))
K1 & K2 an be deduced from the resistor values
t_n_k
Joined Mar 6, 2009
5,455
At this point the question is only concerned with the voltage Va(t) and not the source 'Sync-out' . If the level at 'Sync-out' was quoted rather than Va(t) then one would have to consider a more complex analysis. What you have done is correct.
