input current of single phase controlled bridge rectifier
Discussion in 'Homework Help' started by cpleng7, Mar 19, 2011.
  1. cpleng7
    Thread Starter Active Member
    Dec 18, 2008
    120
    May I know how to calculate input current for single phase controlled bridge rectifier?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    It's not that simple, since the current depends on the type of load. For a purely resistive load then a possible solution would be
    I_{rms}=I_m \sqrt{\frac{1}{2}-\frac{\theta}{2 \pi}+\frac{sin(2 \theta)}{4 \pi}}
    where Im=peak current & θ= firing delay angle
  3. cpleng7
    Dec 18, 2008
    120
    this Irms formula not finding the Irms for the output current?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    The RMS values for load current and input current would be the same.
