Input cap polarity for electret mic preamp
Discussion in 'General Electronics Chat' started by tracecom, Nov 25, 2012.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,879
    1,396
    There seems to be contradictory information about the correct polarity of an electrolytic cap used to couple an electret mic to a preamp. What determines whether the plus or minus side of the cap goes toward the mic?
    Thanks.
  2. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    The amplifier you're using.
    Post a circuit diagram.
  3. MrChips
    Oct 2, 2009
    12,636
    3,455
    Measure the voltage across the capacitor and connect the capacitor so that the positive lead is more positive than the negative lead.
    In most cases of low level audio signals it does not matter.
    tracecom likes this.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    If the cap is installed incorrectly and has more than 1.0 to 1.5V across it, it can be destroyed, and most certainly will conduct DC current, screwing up the bias voltages.
    http://electrochem.cwru.edu/encycl/misc/c04-appguide.pdf
    Measure the voltage before you install the cap.
    PackratKing and tracecom like this.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    Some circuits wrongly show a huge 10uF electrolytic coupling capacitor that passes very low earthquake frequencies down to 0.32Hz into the 50k input resistance of a non-inverting opamp.
    Instead a non-polarized 100nF (0.1uF) film capacitor should be used that passes audio frequencies down to 32Hz.
    tracecom and PackratKing like this.
  6. tracecom
    Apr 16, 2010
    3,879
    1,396
    And what size cap should be used on an inverting opamp in a circuit such as the attached?
    Thanks.
  7. #12
    Nov 30, 2010
    16,704
    7,354
    You have a 100k resistor (R2) as the input impedance. The formula is c=1/(2 Pi F 100k)
    Decide your lowest frequency and plug in the numbers.
  8. tracecom
    Apr 16, 2010
    3,879
    1,396
    So for 32 Hz, the cap should be .049 μF? (Math isn't my strong suit.)
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    You have a zener diode feeding power to the electret mic. But the zener diode is not necessary and it produces a lot of noise. A zener diode is used in many noise circuits. Repace the zener diode with a 47uF capacitor to ground.
    The electret mic uses a current of about 0.5mA so the voltage drop across the 11k worth of resistors is 5.5V then the mic gets only 3.3V without the zener diode which is fine.
  10. #12
    Nov 30, 2010
    16,704
    7,354
    That's the answer I get. Side effect: using a .047 to .05 uf cap puts you in the range where you can use non-polarized caps. Poly-something is a good choice for audio circuits because of the tiny dielectric absorbtion loss.
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    I usually use 220nF (0.22uF) poly capacitors for coupling audio (into 50k ohms) but I have used values as high as 1uF and they are still pretty small.
