ok look this codeI dont understand what you mean by that.
module acc(D,ld3,clk,Q);
input D;
input ld3;
input clk;
output Q;
reg[3:0] Q;
always @(posedge clk)
begin
if (ld3==1) Q <= D;
end
endmodule
module tempacc(D,ld4,clk,Q);
input D;
input ld4;
input clk;
output Q;
reg[3:0] Q;
begin
if (ld4==1) Q <= D;
end
endmodule
module tempaccreg(D,ld5,clk,Q);
input D;
input ld5;
input clk;
output Q;
reg[3:0] Q;
begin
if (ld5==1) Q <= D;
end
endmodule
module register(D,ld,clk,Q);
input D;
input ld;
input clk;
output Q;
reg[3:0] Q;
begin
if (ld==1) Q <= D;
end
endmodule
register R1(A,ld1,clk,B);
register R2(B,ld2,clk,C);
ok I think I understood how does one component connect with anotherEach D and clk exists only inside that module. In other words, the D in tempacc is completely not related to D in tempaccreg. Two completely different signals, even though they have the same name.
A module is similar to a function in C or pascal, if you want to look at it this way. Or similar to a component like for example 74HC04 ttl chip.
When you write this:
You define a component that has three inputs and one output.Code:module register(D,ld,clk,Q); input D; input ld; input clk; output Q; reg[3:0] Q; always @(posedge clk) begin if (ld==1) Q <= D; end endmodule
Then when you writeinside the core_v you use the component "register" two times. One will be called R1 and the other R2. Wire B connects the output of R1 to the input of R2[/QUOTECode:register R1(A,ld1,clk,B); register R2(B,ld2,clk,C);
by Robert Keim
by Jerry Twomey
by Jake Hertz
by Jake Hertz
