Input and Output Capacitance on a EPLD
Discussion in 'General Electronics Chat' started by jasoto, Sep 18, 2014.
  1. jasoto
    Mar 10, 2012
    11
    The datasheet of my EPLD shows sn input capacitance and output capacitance of 10pF. What is the effect on my device caused by the input and output capacitance?
  2. jasoto
    Mar 10, 2012
    11
    In other words, what effect cause these capacitance in the performance on my device?
  3. #12
    Nov 30, 2010
    16,704
    7,354
    I don't even know what an EPLD is, but I can say it's about time. Any limited current that has to charge a capacitance to x number of volts will take time. In this case, probably in the nanosecond range.
    jasoto likes this.
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    Usually a Electrically Programmable Logic Device, you essentially program your own unique logic in the IC rather than use standard logic gates etc, I played around with PLD's in the 80's-90's but Micros and FPGA's have tended to replace it AFAIK.
    Max.
    jasoto likes this.
  5. jasoto
    Mar 10, 2012
    11
    thanks
