initialization process of NHD2.825664UMB3
Discussion in 'The Projects Forum' started by mahmoudathab, Apr 13, 2013.
  1. mahmoudathab
    May 20, 2011
    24
    can someone tell me about the initialization process of NHD‐2.8‐25664UMB3*?? anything might be helpful even about a different OLED.
  2. DickCappels
    Aug 21, 2008
    2,768
    668
    Its already done for you. From the datasheet:
    8.2 Reset Circuit
    When RES# input is pulled LOW, the chip is initialized with the following status:
    1. Display is OFF
    2. 128 MUX Display Mode
    3. Normal segment and display data column address and row address mapping (SEG0 mapped to
    address 00h and COM0 mapped to address 00h)
    4. Display start line is set at display RAM address 0
    5. Column address counter is set at 0
    6. Normal scan direction of the COM outputs
    7. Contrast control register is set at 7Fh
