Initialising HD44780 LCD with p18f252 and MPLAB
Discussion in 'Embedded Systems and Microcontrollers' started by richie244, Apr 30, 2009.
  1. richie244
    Apr 30, 2009
    I am currently do a project where I want to display a volatge on an the 20x4 LCD display.
    I currently have an 8 bit binary comming out of the Pic and have checked this using a logic probe.
    The first problem I ma having is when I attach the outputs from the Pic to the LCD they all go logic High with nothing showing on the display do I need to add a resistor to a circuit before it goes to the LCD display?
    I am aware I need to initialise the LCD and have written a program to do so but I am not sure if it is correct. I have had trouble posting a copy of my code but will try. All I want to do is to be able to control the display even being able to display an "A" would give me a warmer feeling.
    This is the Code I have been trying. I havent included the A/d code because, as you can see it is Very long as it is. :)
    * Display
    #define lcd_rs PORTCbits.RC2
    #define lcd_rw PORTCbits.RC3
    #define lcd_e PORTCbits.RC4
    #define lcd_ret 0x10
    #define lcd_cmd_wri 0x00
    #define lcd_data_wri 0x01
    #define lcd_busy_rd 0x02
    #define lcd_set_function 0x3C //00111100 8 bit interface, 4 line mode, 5x11 dot format
    #define lcd_set_visible 0x0F //Display on, cursor underline on, cursor blink on
    #define lcd_set_shift 0x16 //Cursor move, Right shift
    #define lcd_set_mode 0x06 //Increment, display shift off
    #define lcd_set_cgaddr 0x40
    #define lcd_set_ddaddr 0x80
    #define lcd_clr 0x01
    #define lcd_init 0x30
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    int i,j;
    const int Twentyms = 640000;
    const int Tenms = 320000;
    const int Onetwofivems = 4000000;
    const int Twohundredus = 6400;
    const int Onehundredus = 3200;
    const int Sixtyfourms = 2048000;
    void delay(int);
    void WrCmd2Lcd(char cmd);
    void WrDat2Lcd(char data);
    void InitLcd();
    void Speech(char words,int position);
    void LcdWait();
    void LcdPutPar(int par);
    void LcdEnable()
    lcd_e=1;
    j=Tenms;
    for (i = 0; i < j; i++); //delay for 10ms
    lcd_e=0;
    TRISB = 0x00;
    lcd_rw=0;
    lcd_rs=1;
    PORTB=cmd;
    LcdEnable();
    TRISB =0x00;
    lcd_rw=1;
    lcd_rs=0;
    PORTB = data;
    LcdEnable();
    void InitLcd()
    lcd_e=0;
    j=Onetwofivems;
    for (i = 0; i < j; i++); //delay for 125 ms
    WrCmd2Lcd(lcd_init);
    j=Twentyms;
    for (i = 0; i < j; i++); //delay for 20ms
    LcdEnable();
    j=Twohundredus;
    for (i = 0; i < j; i++); //delay for 200us
    LcdEnable();
    j=Onehundredus;
    for (i = 0; i < j; i++); //delay for 100us
    WrCmd2Lcd(lcd_set_function);
    j=Tenms;
    WrCmd2Lcd(lcd_set_visible);
    j=Tenms;
    WrCmd2Lcd(lcd_clr);
    j=Onehundredus;
    WrCmd2Lcd(lcd_set_mode);
    j=Tenms;
    WrCmd2Lcd(lcd_set_ddaddr);
    j=Onehundredus;
    PORTB = lcd_clr;
    delay(1000);
    PORTB = lcd_ret;
    delay(4960000);
    PORTB = lcd_set_mode;
    delay(1280);
    PORTB = lcd_set_visible;
    delay(1280);
    PORTB = lcd_set_shift;
    delay(1280);
    PORTB = lcd_set_function;
    delay(1280);
    PORTB = lcd_set_cgaddr;
    delay(1280);
    PORTB = lcd_set_ddaddr;
    delay(1280);
    PORTB = lcd_busy_rd;
    delay(1280);
    PORTB = lcd_data_wri;
    delay(1280);
    PORTB = lcd_cmd_wri;
    void LcdWait()
    int status;
    TRISB=0xFF;
    TRISB = lcd_busy_rd;
    do
    lcd_e=1;
    status = ADCON1;
    lcd_e=0;
    while(status & 0x80); // test busy flag.
    char *textptr;
    //textptr = words;
    WrCmd2Lcd(position);
    LcdWait();
    j=Sixtyfourms;
    for (i = 0; i < j; i++); //delay for 64ms
    do
    WrDat2Lcd(*textptr);
    *textptr++;
    while(*textptr != '\n');
    TRISBbits.TRISB0 = PORTBbits.RB0,par & 0X01;
    TRISBbits.TRISB1 = PORTBbits.RB1,par & 0X02;
    TRISBbits.TRISB2 = PORTBbits.RB2,par & 0X04;
    TRISBbits.TRISB3 = PORTBbits.RB3,par & 0X08;
    TRISBbits.TRISB0 = PORTBbits.RB4,par & 0X10;
    TRISBbits.TRISB1 = PORTBbits.RB5,par & 0X20;
    TRISBbits.TRISB2 = PORTBbits.RB6,par & 0X40;
    TRISBbits.TRISB3 = PORTBbits.RB7,par & 0X80;
    void main(void) {
    // unsigned char voltage1, voltage2;
    while(1){
    // voltage1 = readADC(0);
    // voltage2 = readADC(1);
    //InitLcd();
    // WrCmd2Lcd(0X06);
    // LcdEnable();
    //clear display
    lcd_e = 1;
    lcd_rs = 1;
    lcd_rw = 0;
    WrDat2Lcd(00100001);
    // LcdWait();
    while(1);
    void delay(int x){
    int i=0;
    for(i=0; i<= x; i++);
