I will try to get the number off the timer, but it is all wired in on a board and maybe not easy to get at. The switch is rated at 3amp 500v DC
Do you have a present drawing or set up you can post?Many thanks Max for your help, I am going to try again just connecting it up, if the switch malfunctions again I will have to go to a low DC voltage circuit to the switch with another relay to the AC circuit.
Normally you would not use a small reed relay to operate a mechanical relay directly, it would trigger the timer relay input which would be low impedance normally.but the switch operates a timer relay which in turn powers the fan overload and contactor.
I have just had another reed switch destroy itself, but at £10 a pop !
by Jake Hertz
by Jake Hertz
by Jake Hertz
