@bluebird,
BMorse have proposed a feasible solution and a high tech one.
This is an alternative low tech way trying to ease the problem. It is suitable for other forum members who don't/can't have the ability to program a MCU to do the caller ID decoding.
You might consider a telephone answering machine driving some sort of circuit adapter to connect/disconnect your phone. During the day, a timer connects the incoming line to the phones and bypassing the answering machine. At night time, the answering machine is in circuit and handling all incoming calls. When someone call in at night, s/he will hear the following message:
"You have reached Bluebird instead of XXXX_ISP, you'll need to dial xxx-xxx-xxxx for XXXX_ISP. If you actually want to call Bluebird, hang up now then redial after exactly one minute."
The adapter circuit then connects all your phones to the line after 50 seconds, for a period of 30 seconds to allow others to call in. This way you can have your sleep and would not miss any important or emergency calls.
