Inhibiting the phone from ringing
Discussion in 'The Projects Forum' started by Bluebirdiran, Mar 17, 2010.
  1. Bluebirdiran
    Feb 5, 2010
    62
    Hello to all the experts out there!
    I have this telephone number that is similar to an ISP company's except for one digit. This number is sometimes wrongly dialed by the public who want to login to this company through dial up. This happens very often during the night when I am asleep. You can imagine how annoying that can be.
    Can anyone help me to build some kind of a device that can inhibit the phone sets from ringing at specified time intervals. I cannot unplug the phone sets from the wall, firstly because there is more than 3 upstairs and downstairs and secondly, I will definitely forget to plug them back in again in the morning. I speak from experience here.
    This device should to be able to do its job just by plugging it into any empty tel. socket anywhere in the house. It does not matter if it has to include a Microprocessor and programming. Anything is better than getting wakened in the middle of the night!!
    Thanks to everyone,
    Bluebird
  2. retched
    Dec 5, 2009
    5,201
    313
    You could use a relay to give an off hook for a preset time.
  3. Bluebirdiran
    Feb 5, 2010
    62
    Hi retched,
    It is a good idea to start with. But I would like to have a configurable device where I can tell it to inhibit all incoming calls between say 12pm and 7am evrey night. I don't really want to do this manually every night since I am sure I will forget to "unset" it in the mornings. Any other ideas?
    By the way if you leave the phone on an off hook state for too long the tel. company will disconnect the line.
    Cheers Bluebird
  4. KMoffett
    Dec 19, 2007
    2,586
    234
    How about a 24-hour wall plug timer that drives an AC relay that disconnects your phone line?
    Ken
  5. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    First...
    Complain to the phone company, and ask for a new number.
    Good Luck,
    Ifixit
  6. Bluebirdiran
    Feb 5, 2010
    62
    KMoffet, That means digging the wires out and making a mess.
    ifixit, It is such a round number that I will not change it for the whole tel. company and I have been known by this number for a long time, so it is inconvinient to change it.
    Lets have some more constructive ideas!! What I want is a device that you can plug into an empty socket and then do the adjustments and then you can unplug it if you expect an important call in the middle of the night! ( this happens to me sometimes)
    Bluebird
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    You need to disconnect all phones with a timer.
    Shorting the telephone line will result in the telephone company sending out a repair man at your expense to fix the short that you cause if you simply short-circuit a telephone outlet.
  8. ifixit
    Nov 20, 2008
    639
    110
    A 1000uF/100V cap across the line would short out the ring signal, but not cause off hook. You'll have to experiment to be sure.
  9. retched
    Dec 5, 2009
    5,201
    313
    I used to take a phone off the hook all night. What would be required to do the same electronically? A relay and a resistor? Something different?
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    A phone off hook for a few minutes without in a call causes the central office to create loud beeping on the phones then if the line remains off-hook the central office disconnects the line temporarily or permanently.
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    The capacitor would short the ringing signal and cause the line to answer for a moment.
  12. retched
    Dec 5, 2009
    5,201
    313
    Yeah, bad idea.. If you needed 911 in the middle of the night, there is no saying how long you would have to hang the phone up before they reconnected your line before you could get a tone to make the call.
  13. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Wouldn't it be cheaper to buy a phone with a ring on/off switch?
  14. retched
    Dec 5, 2009
    5,201
    313
    Have you seen the prices for those things? GEEZ!
    Talk about highway robbery!! ;)
  15. Heinz57
    Dec 16, 2009
    24
    What about a normal store brought wall socket timer? Just plug your phone into the timer and that into the wall socket? You can just not use the timer if you are expecting a call.
    Just a thought
  16. ifixit
    Nov 20, 2008
    639
    110
    That's a good thing. The computer that's mis-dialing will just fail sooner and sleep is not disturbed.
  17. Audioguru
    Dec 20, 2007
    9,411
    896
    My new wireless phone costed much less than the cost of the battery on the previous wireless phone and it came with the same but brand new battery. It costed nearly nothing (like a couple of coffees at a restaurant). It has a ringer on-off switch.
    A wireless phone is not a cell phone.
  18. retched
    Dec 5, 2009
    5,201
    313
    I have an idea.
    Use call forwarding to send your calls between the times you go to bed and wake up to "weather" or "time".
    If you can get an autodialer, you could have It set your call forwarding at a specified time, and disable at the other specified time.
    You could even write a simple program to have your PC's modem to make the call forwarding settings.
  19. steveb
    Jul 3, 2008
    2,433
    469
    I seem to remember in the old days we would dial our own phone number. This would give a busy signal, but you could leave the phone off the hook for a long time that way. I can't say if this still works or not.
  20. BillB3857
    Feb 28, 2009
    2,402
    348
    I don't know about other phone systems, but our ATT service causes the house phone to ring one time during the "Call Forward" routine. The house phone can't be answered if forwarded, but still rings once for any incoming call.
