Infrared Sensor
Discussion in 'Homework Help' started by tidalwave62, Nov 6, 2015.
  1. tidalwave62
    Nov 6, 2015
    I am trying to interpret the schematic for this IR sensor. I can figure it out, but I can't figure out that the 'uC' element is, and I don't think its micro-coulomb... Please help me determine this, or point me in the right direction.
    Attached is a screenshot from the datasheet, and here's the link to it:
    http://arduino-info.wikispaces.com/...838HS.pdf/264668680/IR-Receiver-AX-1838HS.pdf
    Thank you,
    Joe
  2. shteii01
    Feb 19, 2010
    3,507
    512
    Microcontroller.
  3. tidalwave62
    Nov 6, 2015
  4. shteii01
    Feb 19, 2010
    3,507
    512
    The sensor does not have 3 outputs. The sensor receives the power/electricity through 2 pins. Page 4, lower right corner:
    1 is Output of the sensor, this is the pin you hook up to the input of the uC.
    2 is Ground.
    3 is VCC, 2.1 to 5.5 volts.
    Since you got this sensor info from arduino website, I would dig there and see how it was used with Arduino product.
