Infrared proximity sensor bandpass filter calculation
peskywinnets
Joined Jan 19, 2009
47
I'm just looking at this application note...
http://www.maxim-ic.com/app-notes/index.mvp/id/4622
...on the receiver side they have a '2nd order bandpass filter centred at 10khz' (10khz being the carrier frequency they used)....I'd like to use the same circuit but would need the carrier frequency to be a bit higher at 15.625Khz ....how can a decide on the capacitor/resistor values for the bandpass filtered to be centred at 15.625khz?
I tried to find the formula...but then I spontaneously combusted.
Many thanks,
pesky.
34,285
If you change the values of the 2.49kΩ and 475kΩ resistors by the ratio of 10kHz/15.625kHz the center frequency of the filter should change to be near 15.625kHz. Simulating in LTspice I determined that the original center frequency was closer to 9kHz rather than 10kHz and that standard resistor values of 1.24kΩ and 249kΩ give a nominal center frequency of 16.5kHz -- close enough for this application.
