Infrared photodiode and photodiode
Discussion in 'General Electronics Chat' started by bug13, May 16, 2013.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi guys
    I got a silly question, are infrared photodiode and photodiode the same thing? I got photodiode but it looks like an infrared photodiode.
    Because it looks like a LED with dard red/black casing.
    Hope I am making sense.
  2. Meixner
    Member
    Sep 26, 2011
    116
    21
    Yes they are the same.
  3. timescope
    Member
    Dec 14, 2011
    298
    44
    Which is like saying a Ford and Mercedes-Benz are the same: they are both cars.
    An infrared photo diode is designed to work in the infrared part of the electromagnetic spectrum. The spectral characteristics depend on the material used to fabricate them:
    https://en.wikipedia.org/wiki/Photodiode
    Timescope
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  5. Markd77
    Sep 7, 2009
    2,803
    594
    Inside they are the same thing, but the dark casing is to filter out most of the visible light.
  6. Meixner
    Member
    Sep 26, 2011
    116
    21
    Yes but they all peak in the infrared region.
  7. timescope
    Member
    Dec 14, 2011
    298
    44
    Not all peak in the infrared region of 700nm to 1mm, for example the Sharp BS120 peaks at 560nm and is characterised for visible light.
    Timescope
  8. bug13
    Feb 13, 2012
    1,213
    38
    So if I want to make a proximity sensor out of infrared led and infrared photodiode, I will need a matching wavelength pare?
  9. timescope
    Member
    Dec 14, 2011
    298
    44
    A matched pair would give the best results.
    Something like this
    Timescope
  10. Meixner
    Member
    Sep 26, 2011
    116
    21
    Without a part number to go by, chances are the photodiode he has is infrared. As are 99.99% of photodiodes.
