I got a couple of 240 VAC infra red heating panels that came with what look like heavy molex connectors
Each panel came with two connectors One Male and One Female
The wires are Red, White, and a Yellow/Green-Ground
In each panel they exhibit continuity across the Red and the White ( which makes sense for an electric heat panel).
My assumptions:
1) I'm pretty sure I can feed power into either the male or the female molex connector and
2) that the other one is to connect a second panel in series.
The red and white wires end up reversing across a molex connection pair (see pics)
So My Question is Am I correct about my assumptions?
Milli grazi
My assumptions:
Milli grazi
