Infrared LED
Discussion in 'General Electronics Chat' started by bug13, Jun 14, 2013.
  1. bug13
    Feb 13, 2012
    1,210
    38
    Hi guys
    I see different wavelength like 940nm and 850nm etc, what's the pros and cons for different wavelength?
  2. WBahn
    Mar 31, 2012
    18,078
    4,917
    I think you will find that the 850nm LED will be much more visible to the naked eye even under pretty bright conditions or from some distance away, while the 940nm LED will be quite hard to see under most conditions or beyond a pretty small distance.
    The 850nm LED will probably give you better resolution capability, depending on what you are trying to do.
    bug13 likes this.
  3. Shagas
    May 13, 2013
    802
    74
    If you are using And infrared LED to pair with an infrared sensor then don't forget to have your sensor at same wavelength
    bug13 likes this.
