I'm looking to use an infrared LED and photodiode as a simple switch, i.e. turn the LED on and across the room the some other device turns on.
I've read around the subject and there are some devices that need a 38kHz signal to for the receiver to respond but I cam across this deivce - http://www.soselectronic.com/a_info/resource/d/sfh203.pdf - that would seem to be a simple photo diode.
Questions are:
Questions are:
- can that device work with out a 38kHz signal?
- what would be a good circuit for switching based on that device?
- are there any disadvantages (I assume the 38kHz is there to filer out environmental "noise" from other IR sources)?
