Hi everyone.
First of all I am new here, but I know a good bit about basic electrics. I have a model railway with an automatic level crossing.
The crossing is controlled by reed switches, the lights start flashing when the train is approaching, and when the train passes another reed switch turns the LC off. This can also be done using a push button from my control panel.
HOWEVER, I want to replace the reed switches with Infrared detectors so the trains will not require magnets to be attached to them (I have quite a few).
I think what is needed is a relay which uses IR, that acts as a push button starting the LC sequence (which was a pre-made circuit).
I have acquired the following parts on eBay as I thought the circuit would be easy, but when wired in, the IR detector just lets the current flow so it is not a switch.
L-34F3C IR LED Infra red infa Emitter diode
L32PC3 LED Infra red infa Detector photo transistor
These are the parts I have, they are 3mm diodes, but could anyone recommend a relay or other components that could possibly achieve what I need.
Thank you so much, Bob.
