infra red remote project help
Discussion in 'The Projects Forum' started by tibbles, Sep 29, 2009.
  1. tibbles
    Thread Starter Active Member
    Jun 27, 2008
    following on from my earlir post on a tv agc.the next logical step would be to tap my agc into the scart lead,im a bit reluctant to risk my tv or digibox at the moment by doing this.
    however there are a few occasions when i need to alter the volume manually,ive looked at many devices and circuits to provide remote volume control, ideally using my sky remote,
    these are either hugely expensive or use a processor which is way beyond my capabilities.
    im thinking of building a cheap and cheerful two channel infra red control,
    with a remote sending two frequencies (1 for up 1 for down). the reciever then somehow filtering those frequencies to direct the two signals to forward and reverse a pot motor.the transmitter is pretty straightforward, but i havent a clue on the reciever,so any suggestions on this most welcome.
    i have the output codes for my sky remote which i would prefer to use,-
    up 001 0010 and down 001 0011 if anyone knows how i could build a reciever based on these codes that a beano reader would understand i would love to know.
    many thanks
